Jay wrote:
... but the worst part is that I can't get rid of them. I've gone in as the Team Leader with exclusive access and trimmed the libraries down to just DCA Library.pla and the OBJECTS folder. But the next time I go in, they are all back! What is happening?!
what's happening is that a teammate's library paths are stored as a preference on their local machine. if a teammate is using a different library set (i.e. a local one)
their version of archiCAD knows this when they open the particular draft that it's related to.
what's strange is that a teammate seems to be able to send in some of these libraries to the PLP, but the teamleader doesn't have the priority to get rid of them. (at least the teamleader has
some
privileges now, eh? v8 anybody?)).
you need to assign the library paths as teamleader with exclusive access and delete the teamwork draft preferences of all teammates who've worked on the job. this is found in the users home folder: graphisoft preferences. on a mac this is:
~/Library/Preferences/Graphisoft/AC 8.1.0 v2/
where "AC 8.1.0 v2" is the version of archiCAD you're using. the draft preferences with be the ones in capitals.
note to graphisoft: library management and teamwork is something i've harped on about often enough and needs sorting out ASAP!!!!
~/archiben
b e n f r o s t
