2004-01-28 04:59 PM
2004-01-28 05:33 PM
2004-01-29 06:24 AM
Weston wrote:
Has anybody encountered the situation where AC loads the ArchiCAD Library 81.pla twice during the file open process?
2004-01-30 03:18 PM
2004-01-30 06:34 PM
2004-01-30 07:01 PM
2004-01-31 10:18 AM
2004-02-02 06:51 PM
Has anybody encountered the situation where AC loads the ArchiCAD Library 81.pla twice during the file open process? This is on a new & reset file with cleared caches and preferences. The only path the Library manager shows is to the /Applications/ArchiCAD folder/archicad libraries/ folder. I'm a bit baffled. As the libraries staus window opens, the first time, it loads the .pla as phase 1 of 1. When that one is done, AC then proceeds to open the staus window again, and load the .pla as phase 1 of 13 which of course includes all the standard tools and add-ons.The only time I encountered this was the case I wrote about in that ArchiGuide issue. I suggest you contact GS US Tech Support so they can investigate it for you. There must be something with that machine because even if Library Part are loaded twice, it should not crash.
I am sorry, but I do not understand László Nagy's explanation of PLA file loaded twice when using Library Cache.I think the title of the writing was not entirely correct. I made some modifications to it. I put it here at the very end of my post and soon we will put this new version on the web as well.
How do you change a part in the PLA library?If you plan to modify Library Parts, you need to Extract the contents of the PLA file so you get a Library structure. As you wrote, PLA is good if you do not plan to modify those parts, or don't wish the person to modify them.
If not, then what is AC doing when it loads the different librarys when it states step 2 of 15 and such.ArchiCAD loads Add-Ons, APIs etc., not only libraries. This it always does so there will always be at least a dozen items loaded. Some of these are 'Accessories.apx', 'ArchiCAD.dll', 'Construction Simulation.apx' etc. These are usually loaded so quickly (because of their small size) that you don't see their names displayed.
With respect to my earlier post and you request for clarification: only 1 copy of each library is shown in the dialog at the right - on all machines in the office.Yes, this is a different story from what the ArchiGuide article is about. If you do what is in the article, you see 'ArchiCAD Library 8.1' and 'ArchiCAD Library 8.1.PLA' in the list. So speak to US Tech Sup.
2004-02-03 05:47 PM
laszlonagy wrote:lászló
Library Parts loaded twice when using Library Cache
Written by László Nagy
... The same thing happens when a Local Copy of loaded Libraries is used in the case of a Teamwork Project.
To avoid this, make sure that any network Library does not contain any PLA files.
2004-02-12 06:29 PM
