2026-06-18 04:45 PM
I have a pipe object called ArchiPipe vr 1.3 that I used to use quite happily on an Apple Mac in Archicad 24. Now I'm working in ArchiCAD 28 but if I try to stretch the object either in the 3d window or the Section window it takes ages and ArchiCAD "flickers" and sometimes it does what I want but mostly it just deselects it.
Is this a "feature" of ArchiCAD 28 Windows or is it the ArchiPipe vr 1.3 object?
Solved! Go to Solution.
2026-06-19 12:04 PM
I have no clue about the ArchiPipe object, but my guess is you're using this button?
Well, then... that's a well known bug. Don't use it. Use the pink hotspots instead:
2026-06-19 12:04 PM
2026-06-22 09:51 AM
Thanks that does work.
