Archicad 12 problem
Hi to all!
I put a door 0.05 leaf thickness in a wall, no problem in design1.
I copy the wall and paste in design2
and the problem is the door is not 0.05 leaf thickness is only a simple line!
and is impossible change it in box propierties.
Why?
8 REPLIES 8
Eduardo Rolon
Check the Drawing Scale to see id it is different since how Doors are shown is affected by their Display Scale setting.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Gracias amigo, nunca había perdido tanto tiempo en algo tan simple.
Eduardo Rolon
Por nada. A veces las mas sencillas son las mas difíciles.
AC28 US/INT -> AC08
another Moderator
Eduardo
Otra consulta, nunca había tenido problemas para centrar en un muro una puert,a ahora en A12 no me obedece en el box de previsualización y posición el desplazamiento qué tendré que activar?
Al darle por ej 0.10 (el muro es de 0.20) vuelve a 0.00 y no responde.
Gracias de antemano por tu respuesta
Eduardo Rolon
Switching to English since it is the "official" language of the Forum.
Check your Working Units Precision but it will be easier if you post a screenshot of the "offending" parameter to see what might be the problem.
AC28 US/INT -> AC08
another Moderator
I can't adjust to center door wall !
always its reset to 0.00
Eduardo Rolon
Check Reveal settings. I have no idea how that was translated to spanish.
AC28 US/INT -> AC08
another Moderator
Thanks for your help, but i try on all the parameters not and it is impossible to change 0.00 to 0.05 or 0.1 and the door always is at one extreme.
I do not want return to my A8! where never has problem! but i´m so tired to lose time in middle of project.
I think there is an other general settings variable to affect the doors alignment that never had A8.
Now i´m thinking.............
Always at A8 i make this change but with windows not doors!!!!
And in this particular case the door in 2D is close not open and now i´m not sure if A8 was capable to do it.
