Archicad 19 Library (SE) missing
AlexM09
Hello everyone,
I am looking for the old Archicad 19 default library, but in Swedish. Or the installer for the Swedish version of Archicad 19.
Does anyone have it by any chance?
Thanks!
Alex
try the given link with small caps
https://Graphisoft.com/downloads/Archicad/install/AC19/SWE
I have to write it without a link as it changes some letters by itself, Copy this one, it should work.
EDIT: I can't. Graphisoft gets a capital G and Archicad gets a capital A without any warning. You'll have to do it by yourself.
| Archicad 4.55 - 27
6 REPLIES 6
AlexM09
I am using Windows 10 btw.
Miha_M
Is this the one you were looking for?
EDIT: for me the link doesn't work, but it works if you copy and paste the web address. Maybe you will need to be logged in? If you can't download it I can try to extract the direct download address.
| Archicad 4.55 - 27
And library update:
AC19-SWE-LibUpdate1 – Graphisoft
| Archicad 4.55 - 27
Hey, yes that is the one. But the link is old. Error 404.
I found a mac version of the library in the mean time. So that might work.
| Archicad 4.55 - 27
wow, it worked if all the letter all small caps.
Thanks!
