AlexM09
Archicad 19 Library (SE) missing
Hello everyone,
I am looking for the old Archicad 19 default library, but in Swedish. Or the installer for the Swedish version of Archicad 19.
Does anyone have it by any chance?
Thanks!
Alex
1 Solution
Miha_M
try the given link with small caps
https://Graphisoft.com/downloads/Archicad/install/AC19/SWE
I have to write it without a link as it changes some letters by itself, Copy this one, it should work.
EDIT: I can't. Graphisoft gets a capital G and Archicad gets a capital A without any warning. You'll have to do it by yourself.
| Archicad 4.5 - 29
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
Go to post
6 Replies 6
AlexM09
I am using Windows 10 btw.
Miha_M
Is this the one you were looking for?
EDIT: for me the link doesn't work, but it works if you copy and paste the web address. Maybe you will need to be logged in? If you can't download it I can try to extract the direct download address.
| Archicad 4.5 - 29
Miha_M
And library update:
AC19-SWE-LibUpdate1 – Graphisoft
| Archicad 4.5 - 29
AlexM09
Hey, yes that is the one. But the link is old. Error 404.
I found a mac version of the library in the mean time. So that might work.
Miha_M
| Archicad 4.5 - 29
AlexM09
wow, it worked if all the letter all small caps.
Thanks!
