‎2021-08-16 06:54 PM
‎2021-08-16 08:20 PM
another Moderator
‎2021-08-16 08:31 PM
‎2021-08-17 08:10 AM
‎2021-08-17 02:06 PM
Podolsky wrote:True but it does not change AC's functionality so you can open a file on either.
The main difference between INT and US version (apart of library) that in INT storey count starting from 0. When in US storeys starting from 1.
another Moderator
‎2022-03-07 07:56 PM
Hi Eduardo - Can you please explain in more detail how to install both? Where do I go to install them and where should I install them? I'm in the US, so I'm assuming that I currently have the AC25 USA as default.
‎2022-03-07 08:13 PM
Create different folders for each. I usually have "Archicad 25 USA" and "Archicad 25 INT" folders.
another Moderator
‎2022-03-07 08:14 PM
And where do I go to download the INT library?
‎2022-03-07 09:04 PM
You install AC 25 INT into the INT folder and the library will be placed there.
another Moderator
