2021-08-16 06:54 PM
2021-08-16 08:20 PM
2021-08-16 08:31 PM
2021-08-17 08:10 AM
2021-08-17 02:06 PM
Podolsky wrote:True but it does not change AC's functionality so you can open a file on either.
The main difference between INT and US version (apart of library) that in INT storey count starting from 0. When in US storeys starting from 1.
2022-03-07 07:56 PM
Hi Eduardo - Can you please explain in more detail how to install both? Where do I go to install them and where should I install them? I'm in the US, so I'm assuming that I currently have the AC25 USA as default.
2022-03-07 08:13 PM
Create different folders for each. I usually have "Archicad 25 USA" and "Archicad 25 INT" folders.
2022-03-07 08:14 PM
And where do I go to download the INT library?
2022-03-07 09:04 PM
You install AC 25 INT into the INT folder and the library will be placed there.
