Architrave on angled door
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-04-16
11:17 AM
‎2023-05-24
11:32 AM
Rubia Torres
‎2019-04-16
11:17 AM
There is an angled window object but not an angled door.
This is an AC20 project.
Any ideas?
Thank you[
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
32 GB 2400 MHz DDR4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-04-20 06:36 AM
‎2019-04-20
06:36 AM
Real:
If this door should be under a roof, You would not be able to open it - because the sharp angle would touch the roof ... The other way round it would be ok..
Gdl:
There is a way to get normal Archicad profiles work in GDL following a Tube. This way would be possible, but i have not enough time now to work on it, my duties now are more to play grandpa, so another user here has to take the chance..
Gdl:
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-04-29 12:24 PM
‎2019-04-29
12:24 PM
thanks Hmooslechner, the door is under a staircase so no issues with its opening direction.
I can model it along with its architrave and use the Wallhole comand to achieve the desired result but what I was after is something a bit more "parametric" which would take advantage of all the stndard Archicad door features (ie. Cavity closures etc).
32 GB 2400 MHz DDR4
32 GB 2400 MHz DDR4
