Petros Ioannou
Architrave on angled door
Is there a way for the architrave to follow the wallhole shape on an angled door?
There is an angled window object but not an angled door.
This is an AC20 project.
Any ideas?
Thank you[
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Hmooslechner
Real:
If this door should be under a roof, You would not be able to open it - because the sharp angle would touch the roof ... The other way round it would be ok..
Gdl:
There is a way to get normal Archicad profiles work in GDL following a Tube. This way would be possible, but i have not enough time now to work on it, my duties now are more to play grandpa, so another user here has to take the chance..
Petros Ioannou
thanks Hmooslechner, the door is under a staircase so no issues with its opening direction.
I can model it along with its architrave and use the Wallhole comand to achieve the desired result but what I was after is something a bit more "parametric" which would take advantage of all the stndard Archicad door features (ie. Cavity closures etc).
32 GB 2400 MHz DDR4
