Arrow object - one end an arrow, the other a circle?
rob2218
looking for an object, pline, whatever you can muster that can function in the folllowing manner:
1. should have the ability to have an "arrow head" on one end.
2. should have the ability to have a "circle" on the other end.
3. can add custom text to either end.
we need this object for the stair path of travel.
we can seem to get the stairs to show the correct "UP" or "DWN" on the specific floors we need them to so we are having to shut down the text on the stair objects and just put a simple path of travel (arrow on one end and circle on the other).....
(see graphics attached).
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
23 REPLIES 23
I have made few changes to the original code.
Is this what you wants?
rob2218
you, Andros is DA MAN!.
great object you've created there.
wish you were close by.
I'm sure we could use your GDL programming skills.
humm....now there's a thought?...you don't need to be close by do you.....
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
by the way.....where could you download that object from?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
was actually anylizing this object quit a bit.....by the way...SUPERB JOB AND IT'S FANTASTIC.....
one thing which would be nice also would be to be able to move the "starting node" as a 'stretchy' feature. like you can move all the other nodes. Right now, I have to grab the object and physically MOVE the entire thing to the spot where I want it to start instead of being able to "flex around" all the nodes whereever I need them.
Don't mistake my comment.....like I said....I LOVE THIS OBJECT....you've done an awesome job with the programming.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218,
this object was made by Roberto Corona ("rocorona") from Italy. I just make some little changes that you mentioned in your post.
If Roberto agrees, I will give it to the Object Depository.
rocorona
The original object is from me, you can find it on ArchiRADAR. I wrote it many years ago, and didn't noticed you was using that.
I know Andro is a good GDLer, and I'm happy if he has made it useful for you.
As for the first node not being "free" to move, without dragging the entire object, well, that is possible, but I choosen not to allow it. Maybe is only an idiosyncrasy from me, but I hate if an object can go anywhere, letting it's origin in a lost place, not detectable
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
rob2218
your last point is well taken sir!.
and since you are the originator of the code...well, then I would gladly welcome it in any "revised" form you chose to allow the Archicad community to use it in.....it's a fantastic little object....really.....great work there....both of you.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
p.s.....anxiously (and excitedly - like a kid waiting for a Christmas present)....for the revised object....simply fantastic guys! great work done.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rocorona
Yes, it is ok for me.
_________________
--Roberto Corona--
www.archiradar.com
_________________
_________________
