Athletic Fields? Can't find any GDL's or the like
Gus
It seems to me like someone must have created a library of athletic fields and their dimensions. I just can't find any anywhere. Has anyone found a good resource for GDL objects of basketball courts, volley ball courts, hockey rinks, tennis courts, soccer fields lacrosse fields etc.?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
Have you tried the ones in the standard Graphisoft library?
There is also an 'American Football' field in BIM Components.
Aaron Bourgoin
something you might want to consider voting for: http://archicad-talk.graphisoft.com/viewtopic.php?t=48593
Canadian Football field is an included parameter in the football field object. Thanks.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.1 USA
Rhino 8.25 Mac
MacOS Tahoe 26.1
