Automatic creation of graphical hotspots?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-01-17
03:35 PM
2023-05-24
12:09 PM
Rubia Torres
2006-01-17
03:35 PM
I managed to do a window with a pane controlled by a graphical hotspot. So far so good. Now I want to be able to choose number of panes in the parameter window and get GHs assigned automatically. I can't figure out how to do that...So please enrich me!
AC 25 SWE Full
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-01-30 12:12 PM
2006-01-30
12:12 PM
1. did you use any library window?
2. Did you draw a new window using slab, roofs, ecc.?
3. Did you write any GDL code?
1. If yes, it showld be a parameter to control number of panels
2. If yes, you can't add panes and HS to make it parametric
3. If yes, you can make all parametric (HS included using an array)
Regards
Marco
Regards
Marco
