‎2011-11-30 08:35 PM
‎2011-12-01 03:21 AM
‎2011-12-01 12:22 PM
Barry wrote:Yes, old values where shown.
Just to be clear - you change the values in the info box and then you opened the settings dialogue and they showed the old or default values?
Barry wrote:No, only one basin was selected while dialog box was opened. But the values from info box where changed for multiple basins to bring them to same size.
If this is the case all I can think of is that you may have two basins selected - each with different values of which only one set of values will show.
Barry wrote:Sure
Otherwise if you are changing the values in the object settings dialogue then the info box settings will not change untill you press OK.
