BOTTOM CASING LOCATION
Hi Guys/Gals,
I cannot get my bottom casing to sit in the right spot it. It is un-responsive to changes. It even shows it in the preview in the wrong spot.
Can someone tell me what I'm doing wrong? Or what the problem is. I'm running AC21
Thank you in advance!
Kreg
5 REPLIES 5
Any one out there....... I'm really stuck on this one.
Kreg
What is the exact name of the GDL Object you have problems with? Is this the USA version?
Could you also attach a screenshot of the relevant Casing Settings of the Window? (several screenshots if needed).
Chris Grantham
Has anyone figured this out? Casing continues to show incorrectly and the idea of creating custom complex profiles for all of my windows seems insane. HELP!
16" MacBook Pro M1 Max
Mac OS 26
ArchiCAD 27 Build 6010
You need to tell us what window object and what library language version you are using.
The windows can be different in each language version - i.e. USA is not the same as INT.
Chris Grantham
I am using W1 Casement AwnU 21 from the USA Library.
Maybe I should try the INT library?
Mac OS 26
