Mishi
BUG: SLAB_TOP_SURF AC11
could anyone confirm that the SLAB_TOP_SURF global variable doesn't return with any value. Same experience i have with SLAB_VOLUME.
I've created a label which calculates and shows the result of an attached slab on the floorplan. I used this object in AC9 and that works fine there. In AC11 it doesn't show the values. I tried to debug it with print and the perimeter for example works fine.
Any help or note would be appreciated.
Mishi
Mishi Szabo
Urban Strategies Inc.
Dual QuadCore Xeon Intel Mac 8GB Memory
could anyone confirm that the SLAB_TOP_SURF global variable doesn't return with any value ...
Yes, just realized the same problem.
Have you - or anyone else - found a solution for that ?
Mishi
no but i think it's time to report this bug, because i really need it for our calculation tool.
thanks for confirming it.
Mishi
Mishi Szabo
