Best way to model repeating balcony?
daviiiiidave
Hey Com,
i just wanna ask you something, cause its im possible for me to handle the file by myself.
So on:
I got some socialhousing to work on. 140 Flats with 140 balkonies. As wished we made an balkony steel panel with a pixel pattern. Now i got 4 panels each balkony x 140 balkonies = 560 panels (https://ibb.co/hikr1G).
I made an seperate file with the balkony and put it as an x-ref in the original working file. The panel is made in Rhino/Grasshopper and imported as an 3DM.
Its now as an object placed in the balkony file.
Best way to do it?
ARCHICAD 19-25, Student & Full Archicard, CI Tools, Germany
Mifcom Renderbox AMD Ryzen 9 5900X GeForce RTX 3070 TI 32GB RAM 980 PRO SSD Win10
Thinkpad P52 4K i7 8850H NVIDIA Quadro P3200 (6 GB) 32 GB RAM SSD Win10 Pro
1 REPLY 1
My 2cents would be to create it as a module and then hotlink it back into the main file.
This way if you ever needed to amend the balcony, u only need to do it once.
