Bitmap People for ArchiCAD 11
Does any one know how to put custom photos into the Bitmap People library part?
or
Does any one know where I could get a library part with more Bitmap People than the one that comes with the standard archicad library.
Any help would be well appreciated
Johnson
5 Replies 5
Judit Boros
Graphisoft Alumni
Graphisoft Alumni
To put custom photos into the Bitmap People library part you can do the following way:
Please read the Article on ArchicadWiki.
http://www.archicadwiki.com/TechNotes/How_to_put_custom_images_to_default_bitmap_people
Judit Boros
Technical Support Team
Budapest, Hungary
archicadwiki - the ArchiCAD knowledge base
I've posted before, but can you please repair the bug in the bitmap people object having the 3D representation offset from the 2D location?
Thanks in advance, J
Judit Boros
Graphisoft Alumni
Graphisoft Alumni
The bug in the bitmap people is now added to our error database and we will make sure it will be corrected.
Thank you for the comment,
Judit Boros
Budapest, Hungary
I don't believe this.
Of all the bugs / problems / suggestions that have been mentioned in this forum, this one gets singled out for immediate attention.
Don't get me wrong I am thankful that it has - not that I would consider this high on the list of priorities to fix.
I would just like a similar amount of attention / recognition given to the other issues.
Why do we not get this response from graphisoft more often?
And please Judit keep up the good work of monitoring and replying to the forum.
We like to know where we stand.
We would all appreciate more response like this from other Graphisoft personel.
Maybe you could spread the word?
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Barry,
The Graphisoft Support Team regularly monitors ArchiCAD-Talk, and time to time we pick and investigate problems posted here. We usually stay in the background, or contact people in private mails. This time Judit made a public post because she wrote an ArchicadWiki article on the topic that is probably useful for many.
We can not promise though that every post will be picked up. This team's primary responsibility is to support the distribution channel, and the encouraged way to report problems is through your reseller. We do hope however, that we will be able to spend more time on the Talk. It's something we enjoy doing.
Gergely Kmethy
VP, Customer Success, Graphisoft
