‎2008-03-21 07:07 PM
‎2008-03-22 02:06 AM
Dwight wrote:Lightworks rendering (wohoooo!) + techniques from Lightworks bible (courtesy of Mr. Atkinson) + sketch render techniques described by "tigr" (modified a bit to have some line sketch extensions). Merged both Lightworks render and Sketch render in photoshop using multiply and made the LW render opacity level to 93%.
Dear Mr. Face Paint: could you please confirm your rendering method.
‎2008-03-22 03:47 AM
junior wrote:I don't know... $50 more for Cadimage's A.T. and not having to mess with SEOs seems worth it (IMHO). Be advised... A.T. is not without it's idiosyncrasies.
Or shell out 149.00 USD and get your hands on the D3 Trim+Stair collection and use the "dentil straight" object to produce your Board and Batten Siding. Then use SEOs for where you have door and window openings. See attached image for example:
‎2008-03-23 03:57 PM
‎2008-03-23 04:07 PM
‎2008-03-23 04:15 PM
‎2008-03-23 04:38 PM
‎2008-03-24 03:39 PM
kliment wrote:I think this is a very good idea -- it may be tedious, but better than managing SEOs and individual battens that must be trimmed at each opening!
Well, it cannot be called "quick"!
First you draw your profile with lines, then Magic Wand it with a Wall. But it is better than SEO!
‎2008-03-24 11:57 PM
kliment wrote:Sounds interesting....I gave it a try but strongly feel that I am not doing it correctly. I tried to rtfm but could not seem to pin point a guide to how kliment uses the polygonal wall. Maybe someone could post a step by step process or point me to the right direction?
‎2008-03-25 12:14 AM
‎2008-03-25 12:15 AM
