Botched Library Update
I overwrote my whole AC11 library with the 2008-03-06 library update file. I'm missing all of my surface textures and fear I've overwritten other important info. Is there a way to restore the original GS AC11 Library?
Thanks a lot...
3 Replies 3
Eduardo Rolon
Try here
tr.graphisoftus.com/
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Since you are on 10.5.2, are you running Time Machine? If so, that's the easiest way. Just open Finder to Applications > Graphisoft > ArchiCAD 11 > ArchiCAD Library 11 and then enter Time Machine. Move backwards in time until you see the Texture folders etc shown, select them, and click Restore.
Otherwise, I think you'll have to reinstall 11 from the DVD and then apply the updates again.
did you resolve your problem?
and how?
I have the same problem and i don't know what to do...
The greek reseller told me to reinstall Archicad!
