Lingwisyer
Guru
Bug: Wardrobe Modular Drawer Front
It would appear that the "Drawer with Front" module uses your contour pen to define the colour of it's surface... There is a parameter for it, but it is set to and is inaccessible in the UI. Object unchanged from 22/28. I feel like GS should just not hide the All Parameters list as there are quite a few objects that have parameters missing in the UI.
Setup info provided by author
Deviz
Same issue I just stumbled accross myself.. wonder if 28 has this fixed!
Also one other thing I don't understand is why the knobs and handles available are not the same from all library parts. It's impossible to keep consistency and forces patching up which I really don't like doing
Lingwisyer
Guru
28 unchanged.
The Wardrobe Modular uses the standard GS knob macro, though the "Custom" option appears to be seperate and not included in this object.
