We value your input!
Bug in AC 8.1 & 11 with Object DBX
Attached is the photo that illustrates what I'm experiencing. When I open and object and click on the Mirror object (check mark box), then insert the object, everything works fine the first time. However, if after I've inserted an object and open the Object dbx the second, third, etc, time with the Mirror object (check mark box) still selected and check on the Mirror object check mark box to "unmirror" the object, the object does not show up as mirrored in the display box in the Object dbx.
Basically, it doesn't matter if the mirror object box is checked or unchecked, the object appears the same in the Display window of the Object dbx.
1 REPLY 1
Works fine for me... did you try it with some standard lib parts?
One of the forum moderators
AC 28 USA and earlier   •   macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
