Butt glazed trapezoid window
Hi guys,
I've been wanting to create a butt glaze trapezoid window with parameters . As of now we've been creating each one of them using slab tool and that is time consuming. I started looking into GDL and was able to create a window but then when I change the lower end height of the window it skews the top frame. I've also tried modifying the trapezoid window thats in the library by adding a cut plane but it doesn't look the way I want it.
So my question is, how do I get my top frame to stay a consistent size when I change the angle of the window? I think you use the tangent command but not sure how. once I get the frame to work correctly I could use the cut plane to make the butt glaze.
Hope it all make sense and sorry for the long explanation.
Thanks,
Ruben
0 Replies 0
