‎2010-02-07 06:05 PM
‎2010-02-07 07:06 PM
‎2010-02-07 07:11 PM
‎2010-02-07 07:20 PM
alemanda wrote:You can make the location of the text adjustable so it is visible in the section, and I'm pretty sure you can use GLOB_SCALE to adjust the size to the scale of the elevation. If the stair is against a wall you could embed the text so it is not visible from the other direction.
..mmm
Otherwise I have to add manually the object, the same object, in the section elevation window picking, before adding the object, the properties ...
this is what I want to do automatically ...
If use 3D text there's a problem ... in fact, if the section line is over the 3D text, nothing will be shown ... and moreover the text will scale independent ...
‎2010-02-07 07:27 PM
‎2010-02-08 08:21 AM
alemanda wrote:The label origin can be quite a tricky thing to sort out. Read the globals carefully and try some test code to see where the origins and symbol arrow points are. As I recall you need to do a transformation to zero out the arrow offset but it's been a while.
I'm worried about the origin of the label ...
‎2010-02-08 09:25 AM
