CURTAIN WALLS-USING CUSTOM MULLIONS
Hi All,
I have been trying to explore curtain walls so that I can use custom mullions and transoms to quickly draw balustrades and railings efficiently. as a work around. However, I am unable to bring these custom gdl objects to show in the curtain wall edit environment. Is there a way out or we are stuck with the default settings whose manipulation is only limited to changing sizes and turning objects on or off.
Kind Regards,
Alick.
David Maudlin
Alick:
This was discussed at:
how to create a custom curtain wall frame profile
You can search the forum for more threads, try "curtain AND wall AND custom" for the search.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hi David Maudlin,
Thanks for your reply. I had a look at the thread you are refereing to. Unfortunately the author does not address the problem in a manner that beginners who have no knowledge of gdl scripting would understand. All I am looking for is a possibility to draw mullions and transoms as custom gdl objects. This can open up a huge range of possibilities in using curtain wall tools to actually draw repeattive objects along a path as easy as drawing a polyline like other softwares do.
Kind Regards,
Alick.
