David Larrew
CUTPOLYA bug in AC16
After updating a few of my older objects to AC16, I noticed a bug with the CUTPOLYA command...
The "d" (the distance between the local origin and the end of the half-infinite tube) gets ignored/reset when the object gets mirrored. This sometimes even disables the CUTPOLY command and I loose the cut.
Can anyone else verify my findings? If so, GS please fix!
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
1 Reply 1
Frank Beister
Can you post some examplpe code?
