ā2005-01-14 09:42 PM
ā2005-01-17 07:57 PM
ā2005-01-18 02:52 PM
Just checked mine and all that is the Documentation folder is the MSA libaries. No PDF of the AC9 libraryMillard and others:
ā2005-01-18 05:34 PM
Djordje wrote:Djorde,keene3 wrote:C:\Program Files\Graphisoft\ArchiCAD 9\Graphisoft Documentation\Library Preview.PDF
Does anyone know if ArchiCAD has the capability to produce a Printable Inventory of our Libraries, i.e. a catalogue of sorts...?
Also, try Special menu, Place all objects
ā2005-01-20 10:45 AM
Dan wrote:Yep, it does.
Djordje,Does the INT version install this "Library Preview.pdf" automatically into the folder location as you have described? The US version does not...I had to manually copy that pdf as well as a few others that are on the install disc.
ā2005-01-20 02:08 PM
Djordje wrote:Djorde,Dan wrote:Yep, it does.
The installation CDs are very well worth exploring, quite a bit of stuff is there ...
ā2005-01-21 03:25 AM
David wrote:Thanks David, you are right about it being placed there at installation. I found the folder only by exploring the installation CD and placed them within my Resources folder. I have renaming it "Documents" and moved it to:-Applications/Graphisoft/Archicad 9/Documents, now I can access then from the Help menu.
Millard Brooking wrote:
Look at your ArchiCAD 9 CD, this and other useful pdf files are in the Graphisoft Documentation folder. If you move them to a folder named "Documentation" in the ArchiCAD 9 folder on your hard drive, they will appear under the Help menu in ArchiCAD. They really should be placed here as part of the standard installation process.
ā2005-01-21 03:49 AM
ā2005-01-21 04:00 AM
ā2005-01-26 01:46 AM
Peter wrote:Apologies Peter my typing skills just fall apart in our current heat wave.
Well it seems that, on my machine anyway,
the folder must be named "Documentation"....
