Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. License Manager Tool update is required on Windows. Learn more…
Can models of interior objects (ie: sofa) created in 3D Max be used in Archicad without a conversion? If no, how do I convert it? What other options are there (to purchase) for premade objects?
3DS files can be imported through an add-on. As I recall it is available in the goodies that are posted at GS' website (you can get there from the help menu in AC10).
