Can I edit objects corner cabinet to make it all drawers?
Hello, I want to edit an existing object, I used a corner base cabinet which consists of 1 draw and a cupboard. I cant change the quantity of draws in the settings parameters etc and wondered please if there is any way I can edit the object? If possible I need for the changes to reflect in the 3d perspective. Thank you, any help or suggestions would be appreciated!!
2 Replies 2
If there is no parameter for it then you would have to select the Object and Open it for editing.
But you would have to know GDL quite well to be able to modify the script to do what you want.
Erika Epstein
Or use the multi-drawer cabinet?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
