‎2005-08-09 04:18 PM
‎2005-08-09 06:07 PM
CUTPOLYA 6, 1, 0,
1, 0.15, 5, ! #1 a point
0.15, 0.15, 900, ! #2 a centerpoint, for the arc that's next
0, 90, 4007, ! #3 a 90º arc around the CP above
0, 0.85, 5, ! #4 a point
0.85, 0.85, 900, ! #5 another center
0, 90, 4007 ! #6 another 90º arc
why is it 4007 instead of 4008 and is there a difference?Status for CUTPOLYA has a max of 7 instead of 15. 8, which represents the side of a polygon if you're talking about a PRISM_, doesn't apply. The status is 1+2+4, draw all three lines. EDIT: Forgot about 64. Point is, 8 isn't used, although it doesn't cause an error.
Is the 0,90,4007 defining the curve from one point to another?4000+s is arc around center point. The first term is 0 unless you're doing a circle, then it's the radius. Second term is the included angle, for a circle it's 360.
1, 0.15, -1 ! back to start...which would change the 6 to a 7 of course.
‎2005-08-10 03:19 PM
‎2005-08-10 03:48 PM
‎2005-08-10 04:26 PM
sirduncan wrote:Sometimes it's easier to define a tangent rather than a centerpoint. Check the manual for the 1000 and 2000 statuses.
Instead, I have to define that center point somewhere out in space?
