Andrew Swenson
Can't change window contour pen for composite walls
Hi there
I have had an issue with not being able to set the window contour pen when the wall is a composite wall.
The attached image shows the horizontal window with thick blue contour lines while the vertical window to the left of the image has thin grey contour lines.
I have checked the available settings in my window object, which is the CADimage window object, as well as the settings for the composite wall & the building materials and can't find any where to change the setting.
However I have found that if I change the wall type back to basic I can change the Cut Line Pen setting then change the wall back to a composite wall to get the window contour lines as I want them.
Is this the only way to change the window contours or have I missed something?
I'll try posting images of the wall settings dialog box showing the setting I'm talking about.
ArchiCAD 5.1 - 24
MSI WS63 8SL
Intel i7-8850K @ 2.60GHz
32Gb RAM
Windows 10 Pro 64bit
TwinMotion 2020.2
0 Replies 0
