2023-04-01 05:23 PM - last edited 3 weeks ago by Molinda Prey
When I first tried to choose a line I couldn't do it, because only openingline was available. Then something happened and I could only draw dotted line and no other type of lines. When creating my own type of straight line I cannot choose it.
Screenshot is attached.
2023-04-01 10:32 PM
Are you using macOS Ventura? This is a known issue. If you update to Archicad 26 Update 2 or the latest update to Archicad 25 it will fix the issue. If you don't want to update you can use the arrow keys to select the linetypes.
2023-04-02 09:08 AM
Yes, macOS Ventura. Big thanks!!! You really help me!
