Cannot load Accessories
David Bearss
Have moved to a different computer. Loaded accessories just as on old computer however I cannot seem to get them to work.
I can select a wall for instance and the wall accessory dialog opens however there are no parameters and it indicates "Not available in the loaded libraries"
re-loaded libraries to no effect. I must be missing something quite basic. Any ideas?
David
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
David Bearss
Here is a screenshot of dialog box.
David Bearss
Alienware 17 R5
Did you add the Accessory Library as well? It is a 2 step process for that Addon.
David Bearss
Ahh, that would be it. I did not scroll down for the rerst of the goodies page.
Thanks!
David Bearss
Alienware 17 R5
