Cannot re-size sink inside kitchen bench
How do you do it? I know you can move around the bench to position it within the bench at a different spot but I cannot for the life of me find how to re-size the sink to make it match the dimensions of a clients sink. I am using Archicad 11
1 REPLY 1
The length and width parameters may be all that you can adjust unless parameters have been set up in the object.
But we will need to know the name of the object you are using to say for sure as they are all different.
