Cased Openings...why so difficult to find all the time??
rob2218
Where the heck are those cased opening?
Why aren't they doors?
Why aren't they windows?.....why can't I find them so easily?
In other words....WHAT darn folder is that opening I saw that has casing around the perimeter? I can't seem to seach it? can't seem to remember if they are a window, a door, an object...or what?....where is that darn elusive cased opening?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
4 REPLIES 4
In my Library, the Door called
Rectangular Door Opening 18
has Casing options for both the inside and outside.
Search for it in the Door Settings Dialog.
rob2218
thank you Lasz!
i>u
Edgewater, FL!
SOFTWARE VERSION:
Now, make a favorite of it so you can find it again.
Richard
AC26 (since AC6.0), Win10
rob2218
good point about the favorites.
I've always been, well, shall we say "hesitant" about "favorites"? Why you ask....it's like this...as the project is being developed...I know there will be 'certain' doors, windows, walls, etc...objects that you will use over and over but eventually, 'everything' becomes a favorite and (as Syndrome says)....."once every object is a favorite, then no object will be a favorite"......but I get your point.
Seems there are 'some' objects in the libraries that I have a hard time locating now and then if I haven't used them in a while.....guess I gotta use more archicad ;-D
i>u
Edgewater, FL!
SOFTWARE VERSION:
