Casement window ERROR
For some rease when I try insert a casement window I can't visualize on the preview window and I got the following error message:
Group operation error at line 879 in the 3D script of file wa_trim_us_10.gsm. (System error -1)
how can i correct this?
thanks
9 Replies 9
Djordje
The updated macro is included in the updated US library. AFAIK it is on the US Tech Resources web site.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks Djordje,
It's good to know that I can stop reposting the repaired part now.
Hey I am having the same problem and I have installed the new updated library...Also installed the update on the website...maybe I'm missing somehting? I have the educational version and I constantly get the error when I enter the isometric or anyother 3d view...
Just to clarify...this is what I get:
Fill not found
at line 2403 in the 3D script of file W Storefront 5 10.gsm.
Fill not found
at line 2435 in the 3D script of file W Storefront 5 10.gsm.
I don't know ANYTHING about script...I made this file on a friend's computer and had the same problem there...I downloaded the student version and the all the updates, but the problem persists... before it was file not found not fill not found... I've looked for the macro on the tech website but was unable to figure out which one it was... Please ArchiCad Gods....help me!
oh ok...so i opened a new file and played around...no problem at all then. It seems to be only related to my file which originated on a different machine... any thoughts?
slotownbrian wrote:
Fill not found
Fill not found
The part is calling a fill which is not in the current project attributes. Check the parameter settings (for the placed parts) and see if any fill parameter is listed as missing.
David Maudlin
slotownbrian:
See this topic:
Library Parts Not Working Properly
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Djordje
Matthew wrote:
Thanks Djordje,
There is a post by Ransom Ratcliff on the topic ... and you can put your part in the Depository, where it should be.
Djordje
HP Omen
Of course, silly me.
As my old friend John from Belize always said, "common sense isn't common."
edit: done. It is now in the Doors & Windows folder.
