Rafael Pretti
Change and Object's Plan View Symbol
Hi this is my first post in the community.
I'm using the Ci Select library 26 (2023-11).icf under Archicad Library 26 to place a tree on my project ("tree Cabbage #1050" under Site/Plants Cutout folder) and would like to know if there is anyway I can change the Plan View Symbol.
Ideally I would like it to have the same appearance as "tree Lancewood #1090" but keep the same attibutes (such as cutout and image).
Thank you
Operating system used: Windows 10 business
1 Reply 1
Unfortunately is does not look like you can change the plan appearance.
Each plant in that library is as it is.
