2013-12-06
10:30 PM
2023-05-24
10:51 AM
Rubia Torres
2013-12-06 11:18 PM
2013-12-07 03:08 PM
ejrolon wrote:Or the Rotate command, which changes the opening direction and hinge side.
To switch from outside to inside you will need to open the Door settings and select "Flip".
2013-12-07 10:23 PM
David wrote:But, I believe that Rotate will swap the exterior and interior as far as cladding (materials) and sill/stool go...ejrolon wrote:Or the Rotate command, which changes the opening direction and hinge side.
David
2013-12-08 01:07 AM
2013-12-08 03:38 PM
Karl wrote:True, so best for interior doors.
