Ugljesa Janjic
Changing door swing
Does anyone know how to change the SWING of the door? From a left door to right opening door.
Thanks!!
Ugljesa Janjic
[email protected]
ArchiCAD 25
Mac OS
5 Replies 5
Eduardo Rolon
use the Mirror command. To switch from outside to inside you will need to open the Door settings and select "Flip".
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
David Maudlin
Or the Rotate command, which changes the opening direction and hinge side.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
But, I believe that Rotate will swap the exterior and interior as far as cladding (materials) and sill/stool go...
Ugljesa Janjic
Thank you all! I knew about the Flip. But now I know to use the Mirror or Rotate also. Thanks again! Happy Holidays!
Ugljesa Janjic
[email protected]
ArchiCAD 25
Mac OS
David Maudlin
True, so best for interior doors.
