Church congregation
am designing a church and i need a GD L object that i can easily use to represent a church congregation of a big number seated or standing in prayer..., any help will be highly appreciated.
5 REPLIES 5
you could try something like ArchiPuppet here
However the poly count would get high. It might be easier for you to add the people as images in photoshop?
Erika Epstein
Did you take your camera with you to church this morning?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
thanks alot, but how do i work this out in photoshop with respect to my design for main auditorium and gallary seating?
Djordje
What do you EXACTLY want to do?
1. Show the congregation in prayer in a rendering of the hall
2. Show the figures in your construction documents
If 1, Erika's advice is the best. I would make the billboards using ArchiFacade and place them accordingly. Yes, quite bit of work ... You can do the same for Artlantis.
If 2, use the 2D outlines of people to illustrate the relationship of the seated/standing people and the space designed.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Erika Epstein
There are quite a few posts on this, do a search and also look at Dwight Atkinson's many excellent posts.You should also consider purchasing one or more of his books.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
