Combine 3d with annotation
I there a way to combine the 3D script with 2d annotation in the same object ,so modeling and documentation are set automatically??
I am trying to script a carcass that would have 2d Text and lines when in Section/Elevation. Like a text Shelve or Drawer on top of the elements.
6 REPLIES 6
The only way to do this is by using the TEXT or RICHTEXT command in the 3D Script.
But these will generate 3D Text elements which will add to you polygon count in 3D. Just something to consider. Also, their quality will not be as great as a Text in 2D because curves are approximated by linear segments.
I would rather use a customized label for such need.
Best Regards,
Piotr
label would be a good option but then i would have to create different labels for every object.
I though about adding a 2d annotation mode for the same object to keep the same parameters. This way I could place the object again as annotation, in section or elevation. The problem is it wouldn't update automatically.. but it would be a simple click to replace.
You could check the object's name inside the label and regarding the context the label would change.
Best Regards,
Piotr
How would it read the parameters inside the object though? That's beyond my scripting skills.
Request assocparvalue
(check any label for it)
Best Regards,
Piotr
