Complex profile skin
Guillermo1
Hello , Why the door dont cut one of the skins of a complex profile wall?
Operating system used: Mac Intel-based
6 REPLIES 6
Florin Luca
Check this thread out, it might have the answer you’re looking for:
https://community.graphisoft.com/t5/Modeling/Complex-Profile-Opening-Reference-Line-issue/m-p/401859...
AC27 Solo US, latest build
macOS Ventura 13.6
iMac | 3.8 GHz 8-core Intel i7 | 40 GB RAM | AMD Radeon 8 GB
i think there is no solution to my question in that thread
Did you check the position of the Opening References in your complex profile? I suspected (hence the link) that one of the references is located on the outside face of one skin but not on the other, and bc of that, the door doesn’t cut through the latter. If that were the case, all you’d have to do is move one of the opening references to the correct position. But maybe I’m wrong:)
macOS Ventura 13.6
i have to check it in the complex profile?
If you are referring to the green lines going through the door space, is your door sill above the base of the wall?
That is normal to see the wall sides in that case.
Guillermo1_0-1741370645858.pngthere are fills also that the door dont cut in the wall socket
Setup info provided by author
