Configure number of decimals for hotspots?
I'm using hotspots in floorplan to find points to use as input to the coons-command in GDL. I just drag them from floorplan to the gdl-editor.
But I get so many decimals in the hotspots. I think this is confusing and not necessary. Are there some way in AC to configure the number of decimals that are created for hotspots?
Hello Anne,
I do not know if that answers your needs... but we have a similar question on fc cadlink for reduce a decimal number in an arithmetic expression and Eric Wilk had given quickly this way to solve the problem
if you have meter variables as x1 =1.565488855 and y1 = 3.9899898 for example and you want just two digits after the decimal point.
Try
round_int (x1 * 100) / 100
round_int (y1 * 100) / 100
The GDL Arithmetical Functions ROUND_INT (x) Returns the rounded integer part of x.
Maybe should help you ? Maybe a more elegant solution exist but you must wait for the response of people more qualified
Frank Beister
No, you can't select anywhere the number of decimals, when exporting graphical objects to GDL. AFAIK.
