Connection between wall and window
I have an easy question. As you can see in the picture de vertical connection lines between the wall and my window are to small. I want them to be the same als my walls.
Where can I find this pensetting to solve my problem?
Thx for any help!
charlotte
2 Replies 2
Dontknow
You can set your lineweight (Line Pen) at the settings for your composite structure.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Great!
Thank you very much
