Connection between wall and window
I have an easy question. As you can see in the picture de vertical connection lines between the wall and my window are to small. I want them to be the same als my walls.
Where can I find this pensetting to solve my problem?
Thx for any help!
charlotte
Dontknow
You can set your lineweight (Line Pen) at the settings for your composite structure.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Great!
Thank you very much
