Constructing Corner Windows
Just wondering, how do I make the two sides of a corner window different lengths. I can only seem to make corner windows that are the same size on each wall. Hope this makes sense, Thanks
Once you have placed the window just select the one you want larger and stretch it.
Gerald Hoffman
ā€œThe simplification of anything is always sensationalā€ GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
I'm also having the same issue w/ corner windows. Somehow my AC15 Library only has one empty corner window. So I used the corner window library part from AC9. Here's what I did (please see corresponding jpg):
1. Placed the corner window
2. Stretched one of them longer
3. The result is the 2 windows are separated, leaving the corner wall exposed
Does Gerald or anyone have any idea? Thanks!
David Maudlin
With the ArchiCAD 15 Object Library 15 loaded, you can use the Corner Window tool and navigate to the 08 Openings 15 folder to use those windows. I tried this and was able to place a corner window and stretch one of its legs.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
