Copy Paste grayed out? How to transfer modeled elements from one project file to another?
proto
I want to select a morph in one file and copy it to another file. Two instances of AC26/4034 are open.
The second file was a Saveas of the first, but I deleted a bunch of stuff and have now moved on modifying it. And now, I want to copy some other previously modeled elements over.
I've tried:
1) In 3d view, selecting the morphs individually with the Arrow doesn't show Copy on the edit menu (grayed out).
2) If I put a Marquee around the items in 3d, I do get Copy to show on the edit menu. But cannot see Paste when in the second file.
3) In elevation view, if I select the morphs, I can Copy & then Paste in the elevation of the other file, but I only get fills & lines (?!?) in elevation.
4) I tried dragging the objects to the window of the other file (both in similar 3d view). Doesn't work.
What do I need to do here?
Copy/Paste seems like it should be a basic intuitive feature of the program, but clearly it isn't quite that straightforward.
mac ACv29/3200, US, Tahoe26.1, iMac/2025 Mac Studio
Steve Campbell
You need to have the morph selected in the plan view of a Story to copy/paste the morph model element between files. It won't work in 3D and copying from a Section/Elevation view will only paste lines and fills.
Steve Campbell
proto
Steve, thank you for that reply - I got it to work!
