We value your input!
Corner Window with different Windows panels on each side
Hi Friends,
I am wondering how may I create a corner window with one side having 1 panel the other side say 3 panels. When I adjust the window settings it does so for both windows.
Would you be able to hint me on this problem?
very much appreciated!
Andy
1 REPLY 1
It will depend on what window objects you have but if you use the default Graphisoft ones then simply place two different windows at the corner.
Then in the settings find the controls for the corner and set them as you want.
Attached is a silly example - they wouldn't be different heights.
i.e. don't use the corner window tool as both windows will share the same settings except for length.
