Corner Window
Hello everyone! I have a problem with a window. For some reason, when I try to form a window that turns a corner, it instead forms two windows that intersect each other on the corner. Could it be the wall setting? Happy New Year to everyone!
Thanks
5 REPLIES 5
Dontknow
I've also got a project with a windows that turns a corner.
In the floor plan it looks like that your window frame isn't intersecting right.
What kind of material are you using for your window frame?
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Thanks for your answer. I use metal/aluminum but if you open the full picture you will see how the window acts in different way, I cant figure it why.
Thanks
Link
Try playing with the Custom Corner Functions under All Parameters.
Link.
Thank you for your help. I figure it out just flip the windows
Link
Glad you got it figured out.
Now if only we could insert corner windows into complex profiled walls...
Link.
