2006-09-07 06:52 PM - last edited on 2023-05-24 12:46 PM by Rubia Torres
2006-09-07 09:44 PM
2007-10-14 02:43 PM
Peter wrote:
Yamil,
I am not sure you can auto-script a corner window.
You could model the window by putting in an empty corner window
and then using the slab tool draw in the glass.
If you need stops model those with the wall tool and the slab tool.
I just did this and it looks good.
Peter Devlin
2007-10-14 09:30 PM
2007-10-15 02:06 PM
Peter wrote:Thank you Peter.
Insert a corner window with the dimensions you want then
hit the little square button in the info box to make it an
empty corner window. To make the glass, draw an "L" shape
with the slab tool. This will make the glass continuous around
the corner.
Peter Devlin
2007-10-15 02:35 PM
shute wrote:shute:
but if I try to make it to become a gdl (save as .gsm), the glass has to be drawn facing down. now, I have to add another piece on the edge to form the L shape. when they turned to a gdl, the two pieces do not merge.
What should I do?
2007-10-15 04:28 PM
2007-10-15 04:58 PM
2007-10-16 03:08 AM
David wrote:Hi David,
When saving the slab from the 3D window as a library part, set the 3D view to Top View (not Side View is normally done) so that the slab will be set to the correct rotation you need in this case. The view set in the 3D window becomes the top view when translated to a library part.
2007-10-16 03:12 AM
Srinivas wrote:Thank you for the link Srinivas. In Australian version I'm using, it has no corner frame option as in German one.
Will this be of any help?
http://archicad-talk.graphisoft.com/viewtopic.php?t=15326&start=10
